Ikelite D100 Housing, DS50 etc. etc.
Started by KarstenMoran ·
  1. For Sale:
    1. Ikelite D100 Housing (Ver. 1)
    2. Ikelite DS50 substrobe (new model sells for over $500 with arm)
    3. Flat Port # 5502.41
    4. Strobe arm comprised of components (Fx2, G, E, A)
    5. Ikelite TTL slave
    6. 55mm diopter kit (+1,2,4)
    7. Underwater Kinetics Tundra Case
    The housing and flat port were purchased used from two separate individuals in 2007. They are both in very good condition. Each comes with an o-ring (a spare is available for the housing).
    The housing is the first version of the d100 housing -- it's slightly bigger and there is a bit more room inside than the newer molded ones. I'm not sure if it would be able to fit other cameras in there, i haven't tried.
    The DS substrobe and TTL slave were purchased new in 2004. They have seen limited use and are in good condition and work as they should. See here for item: http://www.ikelite.com/strobes/ds50stdpkg.jpg
    The diopters are practically new and were used on only a few occasions.
    The arm was purchased in 2001 from B&H. It is in good decent condition and functions perfectly. Details here: http://www.ikelite.com/web_pages/arm_comps.html.
    The tundra case is green and it's ugly. But it does the trick.
    Please make me an offer for the lot (email me at karstenmoran_at_gmail.com) -- i might be willing to split it up for the right rate.
    Edited by KarstenMoran
  2. I also have
    - a 100a substrobe (orange) - strobe has a couple scuffs, but works as it did when purchased.
    - additional strobe arm parts (Ikelite)
