Newbie question on compression
Started by scorpio_fish ·
  1. I take a short clip from FCP, export to Quicktime. I now have a 490mg file that looks great when I play it.
    I open the movie in Compressor. I use Apple>Other>Web>QT 7 compatible>H.264 800kbps. I keep the original 720x480 resolution. The file is now 11mg, but the quality isn't particularly good. This is the best quality/least compression of the QT 7 compatible setting for Web settings.
    So, how do I get a compressed version that is bigger and less compressed, i.e. higher quality?
  2. Hi scorpio_fish!
    There are many different ways you could compress your video in Compressor for better results and higher quality. The main limitation in the preset you used is the data rate. Unless you are trying to keep the file size really small, use a higher data rate.
    For your standard def video, try a data rate between 1500 and 3000 Kbps. You can change your data rate in the Encoder portion of the Inspector. As for presets, try the Web>QT 7 compatible> H.264 LAN. You can try the default data rate with this preset and see if you like the result, or in the video settings area of the Inspector Encoder section change the Data Rate restriction to 2000 or 3000.
    Another preset option is to use the Apple Devices>H.264 for Apple TV preset, and in the Encoder section of the Inspector select Apple TV SD for your Device setting. If you don't want this file to open in iTunes as the default application, you can change the default application to Quicktime Player by selecting the file on your desktop after encoding it, using "Command i" to bring up the file information, and changing the default application to Quicktime player.
    Many more ways you could encode this for better results, recognizing that the trade off for better quality is usually a higher data rate and larger file size. Play with these variables and see what works best for your particular video.
    Hope this helps!
    - Mary Lynn
    Edited by Mary Lynn
  3. Thanks for the pointer. Since my original post, I found a tip that worked pretty well. I created a custom setting QuickTime conversion. Set Video compression type to Photo - JPEG. Tweaked the quality setting to get my desired size.
    Now I'll try your technique and compare. Thanks again.
