Any part available to adapt Inon D cable to Inon M cable?
Started by mandarinfish ·
  1. Trying to avoid buying yet more optical cables and use what I have (several Inon Optical D cables). I would like to find an adapter that would allow me to use my D cables with a Nauticam housing. Is there anything like that out there? Or something I can install on the housing side to let me use the D cables directly (like those bushing plugs that can be used for Sea&Sea)?
    Thanks!
  2. i am suffering from the same problem as well
  3. Trying to avoid buying yet more optical cables and use what I have (several Inon Optical D cables). I would like to find an adapter that would allow me to use my D cables with a Nauticam housing. Is there anything like that out there? Or something I can install on the housing side to let me use the D cables directly (like those bushing plugs that can be used for Sea&Sea)?
    Thanks!
    You can drill a small hole in the Nauticam cap and put the naked cable end through the little hole. Works great.
    Bill
  4. Very interesting ... that just took 2 optical cables of the list of things i would need to buy, if i got a nauticam :D
