TROUBLE WITH MY L&M SUNRAY1000
Started by Etc ·
  1. Hi. Hope someone can help me in here.
    One of my sunray 1000 light stopped working correctly. After initial power up from battery pod, every time you press the button it should cycles three differents power levels. If you hold the button power turns off. Well, one them suddenly stopped cycling the light intensity. It turns on/off normally, but it doesn't cycle with single press. I fully charged the battery, I connected the light to the other battery pod, I cleaned the conectors using O-ring grease, I remotelly controled the light from the housing... but nothing changed.
    Someone with this same problem???????
    Thanks in advance.
  2. On my older L & M sunray light pods there is a circular switch surrounding the push button. Make sure this is turned to P and not E. Hope this helps.
    Alan
  3. Have you tried calling Paul at L & M's service dept?
  4. On my older L & M sunray light pods there is a circular switch surrounding the push button. Make sure this is turned to P and not E. Hope this helps.
    Alan
    Well, I can see the P and E embossed labels but there is no switcher. Anyway I have this problem in just one light, the other works alright in both pods.
    I'll try to contact Paul, but I'm affraid he is going to refer me to my national deader, and I don't get along with them too much.
    Thanks a lot.
    Dani
