Which Aquatica Ext. Ring...
Started by giftie ·
  1. ...for use with Aquatica 8" and 12-24DX lens?
    been advised for both #18456 and #18457 (the last one if I am not mistaken is used with the 17-35 lens?).
    Which one are you guys using that gives those sharp corners?
    Jorge
  2. Whichever one is 15mm long. I don't know the model number.
  3. I asked Blake this question at DEMA. 18456 is the correct ring for the 12-14 DX. The same ring as used with the Sigma 14mm.
  4. Many thanks guys. I will not forget your help.
