anyone familiar with the ike d70 housing/i need help
Started by buleetu ·
  1. hi all
    i have a nikon d70 and ike housing do any of u have one,or are u familiar with the housing,im having a bit of a problem i think
    im greasing up my housings knobs and buttons getting ready to go away to the red sea
    yeah know the turny thing right below the shutter release button,,it has 3 cogs attached inside the housing for adjusting shutter speeds or something,,the main cog inside the actually turns the slide on the camera has a bronze screw on it,,i took it off to take the whole assembly apart to clean and grease and now ive noticed the the small steel plate that the bronze screw goes into is actually turning,,its shaped like a 50 pence peice (pentagon like?) i popped it out and has a double o ring, but now that ive put the whole asembly back together the 50 pence peice shape still turns,,, is this gonna leak or is the double o ring there to stop this happening
    thanks everyone
    Edited by buleetu
  2. hi all
    thanks everyone
    does anyone know anyone else that might know??
  3. You could try e-mailing ikelite@ikelite.com they're usually pretty good at responding.
    Edited by KenByrne
  4. You could try e-mailing ikelite@ikelite.com they're usually pretty good at responding.
    calling will get you a faster answer, but I agree with contacting Ikelite directly.
