7D White Balance using Temperature Setting
Started by betti154 ·
  1. Hi,
    I noticed that the 7D has a white balance settings that allows you to set a specific Kelvin temperature. I wondered if anyone has been using this over the traditional approach of taking a shot and setting it to custom. If so, what values have you been using for various conditions/depths.
    As I shoot raw for stills, white balance on the fly is not something I've had to deal much with much underwater so any help would be appreciated. I've been getting reasonable results using AWB when using a mixture of artificial (halogen and LED with 6000K filters) and natural light at intermediate depths (~50m), but on deeper dives with cooler LED lights (no filters) results have been too cool. I don't have the filters anymore too which is an issue.
    I'm shooting video of a deep wreck this weekend using quite cool LED lighting (also have halogen as backup), so am keen to get this right. If need be I'll white balance using at shot of the sand of my hand, though if I can present a temperature that would be better.
    thanks in advance, damien
  2. Hi,
    I don't quite understand what you mean when you say "cool LED". Do you mean they are cool relative the the halogen light (which is true); or are they cool even relative to daylight (and hence the 6000k filter you mention). A properly manufactured LED video light should use emitters that are carefully binned for correct chromaticity...ie daylight.
    I use HID's and LEDs that are 5500K and hence are perfectly balanced for daylight. I set the WB to Daylight and forget it...haven't done a WB for several hundred dives.
    Of course, the lights need to be powerful enough to fill the scene when ambient light is too low. The transition occurs at the same color temperature, thus no need to WB.
    Think of it in terms of the old days of shooting daylight film with a daylight balanced stobe...
    Edited by HDVdiver
  3. HDV,
    I'm talking about a few different lights here. In the past I have used both a Sunray 1000 (5500K) and Fisheye 1000DX (8500-9000K), which are both much cooler than halogen and the fisheye very cold compared to anything. When using the Fisheye's I used 6000K filters.
    I'm in a situation now where I've got a light that is not properly manufactured as we jammed a quad XPG board in an old head, but chose a cool white emitter as it will be used for non-video purposes. I've just taken the optic off and am using it as a video light this weekend (sub-optimal I know, but it's what I have available). It's putting out lots of light and has a really nice wide beam which covered my fisheye lens FOV, but the temp is about 8000K.
    Given where I'm at, I'm just trying to understand how best to white balance the camera for video purposes. I don't have the 6000K filters anymore either so they're not an option. I expect that I either have to:
    1) white balance camera using a still image and custom WB setting
    2) white balance usinga kelvin figure (say 8000K in my case above with bodgy light)
    Depth is in the 80-90m range, so conditions will either be quite pleasant with blue water and mild/dark ambient light (given the last few dives) or pitch black if visibility is down.
    My concern is that when I used the Sunray with AWB results were too cool. Sounds like a daylight or tungsten WB setting would have served me better on that dive. (e.g. http://www.blip.tv/file/3382219.
    I hope that makes my question clearer.
    Edited by Drew
  4. I tried to have a look at your link...but keep getting "Internal Server Error".
    Since the 8000K video light is the primary source of illumination in quite dark ambient conditions just WB for that (or pre-set it if possible...less variability that way). Other diver's lights might look a bit warm but that shouldn't be a problem.
    You can also tweak the color balance in your NLE later if necessary.
  5. thanks, I ran some tests last night in the lounge room and 8000K seemed about right so I've preset it there and will hope for the best. I was trying to avoid post production white balance adjustments on video as I wasn't a huge fan of the results last time I did it. I expect that was because I pushed it too far, but that should be the case this time.
    Re: Link not working, not sure why? It's flash video hosted on blip so out of my control. Seems to work on all the computers I used it on (mac and pc).
  6. It's working OK now...perhaps their server was down for a while.
  7. thanks for the info. 8000K setting seems to work pretty well given the light and water colour combination.
  8. thanks for the info. 8000K setting seems to work pretty well given the light and water colour combination.
    Good to hear it worked out well.
