Nauticam D90 Housing
Started by ckchong ·
  1. I bring up my old post here:
    http://wetpixel.com/forums/index.php?showtopic=35946&hl=
    Bad day.... I thought my problem was solve (remove the camera LCD protector).
    Help help help. Do your guys have any solution. The housing button just slightly touch the camera button. Look like my camera is not big enought to fix into housing
  2. Have your also removed the eyepiece and any straps? I would carefully check for any binding a you slide it into the hosing. Also check to see if the leak detector wires are down out of the way of the back.
    Other than that you'll need to talk to your dealer.
    Jack
  3. Have your also removed the eyepiece and any straps? I would carefully check for any binding a you slide it into the hosing. Also check to see if the leak detector wires are down out of the way of the back.
    Jack
    Hi jack,
    You are right, i need to remove my LCD protector and eyepeice also. Know it work normallyand perfect ... (i hope not just a moment only.)
    This will be help for who using Nauticam housing......
    Many thanks
