Lembeh Wide Angle!
Started by Cybergoldfish ·
  • 13Posts
  • 13Replies
Lembeh Wide Angle!
  1. At first it's easy to assume that it is a dead leaf floating under the surface...
  2. Todd takes a closer look...
  3. Nope... It's a juvenile batfish.
  4. You don't survive this long unless the camouflage is effective
  5. Even fools the birds...
  6. 07.30 - Job done - Time for breakfast!
  7. Ah, the last one's like the one I got. Nice shots.
  8. Yes. Love that last batfish shot.
  9. FWIW, there's a fish in the Gulf of Mexico called a Tripletail that does this behavior. It gets up to like 10 pounds though - that's a big leaf!
  10. Bob, that's a great shot (the last one - # 5). What lens were you using?
  11. Thanks, Yes that's the very shot I was after but the sequence up until then was interesting so I strung it out for 32 exposures to provide a story (This is the short version!). It wasn't there are the beginning of the dive so I shot with the macro setup on the site. When I ascended there it was, so the boatman fetched the WA setup back from the boat. I was using the (used) superb 20mm nikkor (a worthy equal to the 20mm UW nikkor), behind an 8" dome.
  12. #5 really is a shot I wish I had took :huh: - superb!
  13. Thanks again. Problem with wide angle at Lembeh is the amount of crap there is in the water - Disgusting considering that this area is of global interest. On one particular dive I had to blow a hole out of the surface with my reg so I could ascend amid the plastic bags, household rubbish and jellyfish.
    As a consiquense trying to get around scatter is impossible when ordinary sunlight will cause the same effect.
    This is a natural light shot...
