Sea & Sea sync cord
Started by wwlam ·
Sea & Sea sync cord
  1. I got Sea & Sea DX100 for D100 comes with YS-350 Pro and YS-120 dual. only the YS-350 Pro work with TTL, the YS-120 work as slave. I would like to know if I buy a 5 pin dual sync cord, can they both work with TTL? Or need a TTL converter? I alos have a YS-110a. don't know how to make them all work with TTL
    Thanks!
  2. Need help Please
  3. Hi,
    I don't know the answer but the folks at Reef Photo should be able to help.
    Reef Photo and Video
    Hope that helps,
    Ellen
  4. D100 use D-TTL and so I think you need a converter.
    As only a fews pins of the bulkhead have connections to hotshoe of the camera in old sea&sea housing, they need modifications on the bulkhead before they can be used with TTL converter.
    Also I can't find D100 in the compatibility list of Sea&Sea TTL Converter, I think you may need a HW TTL converter.
    http://www.seaandsea.jp/products/accessory/ys.html
  5. Thanks again
  6. I hope it is not too late.
    For the DX-D100 you need to send it to S&S for a modification.
    I understand that not all DX-D100 housings are suited for this modification, it depends on the serial number.
    If you connect a TTL converter to a not suited converter connector will damage the converter and possibly the housing.
    Regards
