Neon Goby, Say Cheese
Started by Marc Furth ·
  1. I’ve been trying to capture one decent picture of this Neon Goby for sometime. My shutter speed tops out at 60th of a second when I’m in TTL mode. This guy stood till and said cheese.
    Marc
    Shutter speed: 1/64.00
    F-stop: 19.0
    ISO speed: 100
    Focal length: 89.0000
    Light source: Single SB 104
  2. Marc,
    What camera are you using? You should be able to get better than 1/60th unless you are using a Nikonos or something I would think.
  3. Hi James,
    I’m still using my Fuji S2 Pro in aperture priority mode.
    Marc
  4. Ah, that's cool.
    Set the camera to M and set your aperture to whatever you desire and your shutterspeed to 1/125th.
    In A, the camera sets the speed depending on available light - so naturally at f22, it will choose the slowest speed - which is limited to a slowest speed 1/60th with flash connected. The fastest you can sync is 1/125th.
    I hope that helps you get some of the shots you were missing.
  5. Your right, I’ll give it a try next dive.
    Marc
