olympus PT-E06 housing
Started by vinny ·
  1. hi
    can anybody let me know the measurements of the tray attachment screws on the base of this housing please?
    i would like to know the total distance from one screw hole to the other end and also the distance between the screw holes
    just want to check if a certain tray will fit the housing and cant find the info i need online anywhere
    thanks in advance
    vinny
  2. It's 3/4" I believe. There are 4 holes, I think.
    Jack
  3. hi
    thanks for your replies
    cheers jack, i think there is more than four holes thou , but i am not sure
    frisco ,i already have a tray just need to know if it will fit , thanks for the help
    just to clarify i have the housing already ( but i have left it abroad)
    i have bought an ikelte camera tray ( i think the standard double handled DSLR tray)
    so if someone has one of these housings ( and can measure it ) or knows that this housing and tray will work let me know
    cheers
    vinny
  4. Hi My housing PT-E06
    Have just Measured
    has 5 holes on the Bottom ( for taking most Trays) I use the Middle 2 which seems Standard
    the Middle 2 have a 45mm centers between and all the holes there is 22.5mm Distance from Middle to Middle
    So you can have any 2 holes with Multiples of 22.5cm
    Hope this Make sense I bought a NEW old model Sea-sea CX tray and Handles for Half Price as older Model from Yuzo @ UWdigitalcamera.com he might still have a Couple left they fit Perfectly
    Hope this Helps
    Mark
  5. Hi Mark
    thanks for measuring it for me , makes perfect sense
    i can check see if this tray will fit now
    much appreciated
    vinny
