Sea & Sea MDX-40D UNderwater !!!REDUCED TO SELL!!!
Started by Steve1987 ·
  1. !!!!REDUCED TO SELL!!!!
    The housing is being sold as part of a package which contains:
    -Sea & Sea MDX-40D Model:
    -Compact Dome Port & Gears; (For 20mm lens)
    -Compact Wide Port L & Gears; (For 18-55mm lens)
    -Sea & Sea Ys110alpha Strobe & TTL cable;
    -Flexi Arm x 1;
    -Clamps x5 & 12 bar lattice x2 for straight arm configuration;
    -UK Hardcase;
    -Extra O-rings & Grease + Documentation.
    -Asking price is €1, 900.
    -This is without the camera, the model of camera that this
    casing takes is a Canon 40D or 50D.
    -The wide angle dome port has a number of scratches from a spider crab but I can say it doesn't interfere with the images
    produced.
    -The casing itself is in very good condition having only been purchased last July 2009.
    -For any questions please email me: stephencomiskey1987@hotmail.com
    Edited by Steve1987
  2. Can you make clear the code for each gear.
    -Clamps x5 & 12 bar lattice x2 for straight arm configuration; - I can not understand . Do you mean ball clamp ?
    -UK Hardcase; what is the size ?
  3. The codes for the lens ports are: 55601 Dome Port plus the corresponding gear for a wide angle 20mm lens.
    30103 plus the focusing gear for an 18-55mm lens. (Still in box never used)
    -ULCS BA-TG-Groove Adapter x1 (Never used)
    -ULCS AD-SS YS Mount x1 (Never Used)
    -ULCS AC-CS Clamp x3 (Never Used)
    -ULCS DB 12 Bar x2 (Never Used)
    To build a rigid arm configuration instead of using the flexi arm.
    Size of the hard case is large, I'll try find out exact dimensions, its large enough to hold the underwater housing, stobe flexi arm and dome port for 20mm lens.
