FS: Sea&Sea DX-D200 with Dome Port, Camera and Lenses
Started by jayhem ·
  1. I'm selling a complete Sea&Sea underwater system for the Nikon D200, in good working condition and ready to take for a dive! Reason for sale: upgraded to D700. I'm going to add detailed photos of everything. Let me know if you have any questions.
    • Sea&Sea DX-D200 Housing
    • Fisheye Dome Port
    • Extension Ring
    • 12-24mm Lens Gear
    • Nikon D200 Body
    • Nikkor 12-24mm Wide-Angle Lens
    • Nikkor 18-200mm Zoom
    • Polarizing Filters + Slingshot Bag
    886161957_KNHi3-S.jpg 886162211_vtE42-S.jpg 886161374_2aCD4-S.jpg 886161856_d6S7s-S.jpg
    Click on images for larger view. More photos of the equipment can be found at http://jayhem.smugmug.com/Photography/SS-D.../12391883_SJ3t5
    Details
    Nikon D200 Digital SLR Camera body
    http://www.amazon.co.uk/Nikon-D200-BODY-Di...a/dp/B000CDG4UK
    Very good condition besides a few minor scratches on the bottom side. The shutter count is only about 15.9K (lifespan > 100K activations), so it should last many years. In original box, complete with battery + charger, 2GB CF card, shoulder strap and all other bits and pieces.
    Currently worth £900 on Amazon, asking for £450
    Wide angle zoom lens: Nikkor AF-S 12-24mm 12-24 f/4 F4 G IF-ED DX
    http://www.amazon.co.uk/Nikon-Zoom-Nikkor-...s/dp/B000092M1T
    Perfect condition, in original box incl. manual and lens shade, currently worth £800 on Amazon, asking £590
    18-200mm zoom lens: Nikkor 18-200mm ED VR
    http://www.amazon.co.uk/Nikon-AF-NIKKOR-18...y/dp/B00319DL94
    Perfect condition, in original box incl. manual and lens shade, asking £350
    I'm selling the whole set for £1290 (worth £2110 new)
    Polarizing filters
    B+W 72mm F-PRO Circular Polarizing Filter with Multi Resistant Coating: £84.80 @ Amazon, like new, asking £60
    http://www.amazon.co.uk/Circular-Polarizer...g/dp/B0000BZL8X
    B+W 77mm Slim KSM C-POL MRC - Circular Polarizing Filter with Multi Resistant Coating: £140 @ Amazon, like new, asking £90
    http://www.amazon.co.uk/Kasemann-Circular-...m/dp/B0002O73AO
    Lowepro Slingshot 100 Sling Bag - Black
    http://www.amazon.co.uk/Lowepro-Slingshot-...c/dp/B000BAX50G
    Perfectly fits the D200 with lens attached + additional lens + accessories.
    Worth £38.09 on Amazon, very good condition, asking £25
    Buy this complete set for £1465.00 instead of £1565.00 (originally worth £2425) and I'll also add two great books for FREE:
    Sea&Sea Underwater Housing + Dome Port - For Nikon D200/12-24mm Wide Angle Lens
    I bought this Sea&Sea system on Wetpixel in June 2008. The first time I tried it out (in a pool) it leaked because the extension ring was scratched, but after a full service and repair by Aquaphot [http://www.aquaphot.com/] in December 2008, it has been working perfectly. The system was pressure tested for 1h at 60m and the dome port has been nicely polished (cf invoice: http://www.evernote.com/pub/jayhem/public#...fc7a61&b=0). I can really recommend Aquaphot for this kind of work, Kevin is doing an amazing job.
    I've only used this system on a few occasions: a big dive trip in Belize and during a few freediving pool competitions in the UK. The system should still be in excellent working condition and is ready to go underwater as-is, nothing is missing. In the right conditions, it will produce amazing results. It's the perfect system for a beginner underwater DSLR photographer, as it's very quick and easy to set up, very robust and costs a fraction of a new system. There is only one O-ring to check between the dives and it's almost impossible to make a mistake that would cause a flooding.
    The system is complete with two spare O-rings, a little bit of spare grease, manuals, O-ring remover, etc.
    If you're interested and can make it to London (UK), I'm happy to show you the system, explain how to set it up, and I can even meet you in a swimming pool, so you can try it out and see by yourself how easily you can get amazing underwater shots.
    The Sea&Sea System:
    Housing : £600
    Dome Port : £220
    Lens Gear : £80
    Extension Ring : £40
    TOTAL : £940 (Total value new ~ £3025)
    Buy the whole camera/lenses/housing/port-system for £2340.00 instead of £2505.00 (original value of about £5500). This includes camera body, lenses, filters, bag, housing, port and all accessories, complete and ready to take for dives.
    Details:
    Sea&Sea DX-D200 Underwater Housing
    Good condition, works perfectly except for the leak detector, but this should be easy to fix or replace, although it isn't really needed. It has been damaged when I tried it for the first time and it flooded due to a damaged extension ring, but after I had the housing serviced and the extension ring fixed, it has been working perfectly ever since. This housing is very robust and easy to use, perfect for a beginner underwater DSLR user.
    For a review of the housing, check out http://wetpixel.com/i.php/full/sea-sea-dx-...for-nikon-d200/
    Original value ~ £2200
    Sea&Sea Fisheye Dome Port - Part # 56401
    http://www.camerasunderwater.co.uk/slr/seaandsea/ports.html
    Good condition. bought second-hand in June 2008, serviced in December 2008 by Aquaphot [http://www.aquaphot.com/] where scratches were removed.
    Original value ~ £570
    Sea&Sea Lens Gear for Nikkor 12-24mm - part # 31107
    Very good condition, works perfectly.
    Original value ~ £105
    Sea&Sea SX Extenion Ring - part # 50261
    Good working condition. It was scratched when I bought it (2nd hand) and caused a leak, but it has been repaired in December 2008 by Aquaphot [http://www.aquaphot.com/] and has been working perfectly since. I'm selling it for a greatly reduced price because it might not resist water damage as well as a new one, but it's working fine for now and will last for years if you treat it well. I haven't seen any corrosion so far and doubt there will ever be.
    Original value ~ £150, asking £40
    Some shots I've taken with this system (click image for large size):
    Edited by jayhem
