Fibre optic cables any good ?
Started by kazb ·
  • 11Posts
  • 11Replies
  1. Hi everyone
    Just got myself a Sea & Sea MDX-D300S housing and it comes with two fibre optic cable sockets for the internal flash. I have two YS-110alpha flashes and they have the DS-TTL function. I also have the synch cables and the TTL converter. Now I was wondering about
    how good the fibre optic cables sollution is - Is it so good that I can leave my synch cables and TTL converter at home when I go to Egypt next month and save the weight ? Or is the cable sollution still the best way to go. Macro and wide wise ?
    Anyone tried them out yet?
    Kenneth
  2. I tried fibre optic flash cords with my Nikon D 300 and Inon 240 strobes and have never looked back. The Nikon iTTL system functions perfectly and I have eliminated six potential flooding/failure points in the process- two camera bulkheads, two strobe cords, and two strobe bulkheads. An added bonus- fibre optic cables are much cheaper than electric cables, are field servicable / replaceable.
  3. Modern optical triggered slave strobes work surprisingly well and today there are not so much (or no) situations where a cabled strobe would do the job better. The only solution may providing better results could be a housed system flash like the Canon Speedlite or Nikon Speedlight as they communicate much more with the camera. But this is a guess from me as i have no experience underwater with my Speedlight but as the housings for it are extremly expensive i go with my Ikelite DS-125.
    Unfortunatly my Ikelite D90 housing does not allow the internal strobe to pop up fully and this block the internal flash from firing
    so on my housing, a slave strobe is unfortunately not possible. :).
    I am experimenting with my G11 in a Patima housing and my old Inon D-2000 strobe and i am very satisfied with the results!
    Chris
  4. Ditto on using fiber. Would suggest taking a spare set just in case one becomes damaged (handling accident, shark bite, etc). Mechanical is always more reliable than electronic. Just make sure that TTL works if you're using it.
    Edited by jcclink
  5. Ditto on using fiber. Would suggest taking a spare set just in case one becomes damaged (handling accident, shark bite, etc). Mechanical is always more reliable than electronic. Just make sure that TTL works if you're using it.
    I use dual fiber cables from a Nexus D80 to inon 240 strobes. Works great; sTTL or manual. I do carry an extra set of fiber cables and a double sync cord. I have never need the elec. cord back up. OK, so I am a worry wart. :)
    Bob
  6. Sounds like I have to give it a try. Maybe I will bring a sync cable just to be sure :)
    Kenneth
  7. If you shoot in blue water an electrical connection can be a lot faster as you don't wait for the camera strobe to recycle. You can achieve much of the same effect with f/o by NOT using TTL and also turning the camera to manual and turning the power down.
    Jack
  8. I'm using a D300 so this should apply to your 300S. Go into the menu & change the flash setting to MANUAL & power to !/100. This is sufficient to fire the strobes via fiber optics, & it minimizes camera battery drain. I still get over 700 shots on a battery using fiber. (I always shoot manual.)
    Also, you cannot shoot CL or CH continuous exposures using fiber optics, but can with sync cord. Camera flash doesn't recycle fast enough. You may get shots but strobes only fire on first one.
    Edited by jcclink
  9. Hi jcclink
    Did you tired CL/CH modes having set the internal trobe to 1/100th of its power?
    In such conditions I would assume a very short recycle time...
    cheers
  10. I also wonder what if you set your internal flash to master, but not to light.
    In that case, I guess you'll have TTL, but not much recycle time since your internal flash is not supposed to provide a lot of light.
    Though I don't know Nikon's TTL protocol, maybe 'SHOOT STRONG' means a strong pre-fash?
