Help neededsetting up E-620 with Inon s-2000 strobes
Started by globalmark ·
  1. Hi I posted over on the Strobes Page but no real replies there so Try here.
    I have a Olympus E-620 in PT-E06 housing with x2 Inon s-2000 strobes - and I am trying to find out more about the Settings I need to make work Better .
    Is strobe setting Manual or S-TTL better to use most of the Time ?
    If using on S-TTL where do I put the EV switch on the Strobe (what Position)
    Are there any special settings on the Camera I should have set when using S-TTL
    Any other advise or info would be useful on the set up and use .
    One other Unrelated Question the Macro setting on the E-620 (little flower setting) does this actually do anything , as I normally shoot underwater in M-mode should I use MACRO for shooting Macro (does it do something to lens like a Compact Camera)
