LR 2.7 and copyright notice
Started by Alastair ·
  1. I am using Light room 2.7 and i have found how to add the copyright water mark but i need a magnifying glass in order to see it. i remember seeing somewhere that i can enlarge it without resorting to plug ins.
    Can anyone shed some light on this for me?
    thanks.
  2. I am using Light room 2.7 and i have found how to add the copyright water mark but i need a magnifying glass in order to see it. i remember seeing somewhere that i can enlarge it without resorting to plug ins.
    thanks.
    Try using this plugin. If you want to export more than 10 images at once you have to donate. Guess the minimum donation is 0.1$ so that should be affordable
    http://www.photographers-toolbox.com/products/lrmogrify2.php
    not all fonts work, so try a few different.
  3. Or you could just upgrade to the new version 3.0 which has a watermark capability built in. You'd get the sweet new noise reduction capability too. Works amazingly well on our dark blue backgrounds.
  4. Thanks for the advice i think i will go with the LR3.
    cheers....
  5. Or you could just upgrade to the new version 3.0 which has a watermark capability built in. You'd get the sweet new noise reduction capability too. Works amazingly well on our dark blue backgrounds.
    Steve - How easy it is to use this new feature in LR3? I have just started learning LR2 and have found that adding this is very difficult. I tried to download the mogrify plugin - but with no luck.
    Can you give some more specifics on this featurein LR3? - DiverPam
    Edited by DiverPam
  6. How easy it is to use this new feature in LR3? I have just started learning LR2 and have found that adding this is very difficult. I tried to download the mogrify plugin - but with no luck.
    Hi Pam,
    Well I figured it out so it's pretty easy. :) There is a video on Adobe TV that shows the new additions to LR 3 that shows the basic functionality. Video is here. Fast forward to 24:40 if you just want to see the watermark info. Recommend you watch it full screen.
    Have fun!
