Aphibico EX3 or Gates EX1R
Started by ante ·
  1. I am ante from Split - Croatia. Last 10 years I have been recording using PD150 and Amphibico housing. Now I am planing to buy a new equipment. At the moment I am thinking between Amphibico EX3 or Gates EX1R. Any suggestion! It seems that EX3 with Amohibico is quite large and heavy - that is a huge problem if you are alone in the field.
    Best regards from Adriatic
    ante
  2. Also I don't believe the Ex3 housing doesn't actually accommodate any other lens so pretty pointless to me.
    EX1 has advantage of cheaper cam, great SWP44C port and the ability to run into a nano flash drive, Gates Ex1 wins hands down to me if you are buying from scratch, if you already own a couple of EX3's then that would change the playing field.
