FS: Ikelite Canon G9 Housing, DS-125, ULCS Arms, will split up package, $1650 for all
Started by samurai_k ·
  1. I have a baby coming soon and so my scuba vacations will be put on hold for a while. I am a recreational diver so the housing has only been used on vacations in warm water conditions in Hawaii. Up for sale is my Ikelite G9 System. I bought the housing new in Dec 2007 and the first dive occurred 12/18/2007. The housing has been used for a grand total of 16 hours and 26 minutes of bottom time on 17 dives in average water temperature of 78 degrees and average depth of 40 feet. The housing was overhauled in September 2009. Since the overhaul, the housing has been used for 9 hours and 15 minutes of bottom time on 10 dives, with the last dive logged on 5/28/2010. I have always had soaked the housing in a freshwater tank after each dive and made sure the buttons and knobs were flushed out with fresh water. The main o-ring has always been removed, cleaned and lubricated before storing the housing even overnight. The port is clean with no scratches and the TTL circuitry works as it should. For storage and travel, the housing has always been placed in a foam padded Pelican case. The housing has never been flooded, nor dropped. The only scratches on the housing are inside under the plate that attaches the camera. When you slide in the plate with the camera on it, it brushes against the housing, causing some scuff marks. There are hi-res pictures in the flickr album to show you exactly what condition the housing is in.
    The following is a price list for the housing as well as other items for sale which are also in excellent condition.
    6147.09 Ikelite G9 Housing (Includes flash diffuser and flash blocker, main o-ring, TTL port plug, extra overhaul button o-rings and e-clips. Hi-res pictures below.)- $450
    Canon G9 Camera (Camera is in excellent condition. Always have had a protective plastic film on the LCD and the camera has been enclosed in a 2MM thick aluminum shell case by Really Right Stuff. Includes charger, extra battery, Really Right Stuff tripod mount and hard aluminum protective case, Richard Franiec grip. Hi-res pictures below.)- $350
    Buy the housing and camera for $750
    I also have these other items for sale too:
    4065 Ikelite DS-125 (Has same service history and usage as the housing. Never flooded. It was bought new in Dec 2007 and is one of the "newer" models with the correct TTL circuitry. The recall service has also been performed on the battery latch and the main o-ring was also replaced in Sept 09. Includes fast charger, battery, and TTL port plug. Hi-res picture below.)- $500
    4103.51 Ikelite Digital TTL cord (Has same service history and usage as the housing. Never flooded. O-rings replaced in Sept 09. Hi-res picture below.) $75
    Mint condition ULCS strobe arm set that consists of 2-8" arms, 3 ball clamps, and adapters to connect to the housing and strobe. The only thing that shows the arms have been used is some of the anodized coating where the clamps tighten down on the arms. Hi-res picture below. $200
    Pelican case to hold everything $100
    Pictures of Camera and Ikelite System
    http://www.flickr.com/photos/39228657@N00/...57624396979956/
    Recent Dive Pictures in Niihau Hawaii
    http://www.flickr.com/photos/39228657@N00/...57624171803956/
    Recent Dive Pictures in Maui Hawaii
    http://www.flickr.com/photos/39228657@N00/...57624124239698/
    Edited by samurai_k
  2. I am interested in the Strobe
  3. HI Samurai
    don't forget you will want to take pics of baby / toddler etc in the water
    some of my favourites are of the kids
    david
  4. HI Samurai
    david
    Thanks!
    Everything is sold.
    Thanks for looking.
