Nikon 50mm f1.8
Started by malley1717 ·
Nikon 50mm f1.8
  1. 50mm has closest focus of 45cm! Not much use underwater, whereas the 60mm is a dedicated macro lens that can focus down to 18.5cm
  2. ahh thank you panda
  3. You could possibly use it as a macro lens by adding a +4 dioptre.
    I use the 18-55mm with a +4 and it works OK, but not as sharp as the 60mm.
  4. I tried it with +4 diopter behind ikelite 6" dome once.
    Optically it worked fine, but it did not seem that useful.
    See some sample photos:
    50 1.8 samples
