QT and Keynote
Started by Steve Douglas ·
QT and Keynote
  1. Trying to help a friend here: His question is below.
    When I try to import Quicktime movies into Keynote, the aspect ratio changes from 16x9 to 4x3. When I change the ratio, I'm getting lots of artifacts.
    Any suggestions for a smooth export/import from Quicktime to Keynote?
  2. I tried with Keynote '09 version 5.0.3 (791) on 10.6.4 by dragging QT movies from a finder window to a Keynote slide. That copies/embeds the dragged QT movie into the Keynote presentation.
    result: aspect ratio doesn't change (16:10 movies stay 16:10)
    Using the "Media" palette (near upper right corner of Keynote's main window, 3rd icon from right), appears to work correctly also.
    Using menu: Insert/Choose..., same results.
    Hmmm...
    The movies you're importing don't happen to be a video format with non-square pixels?
    Take Care,
    Chris
  3. Apparently it was his QT frame size that caused the issue. Thanks
