sea&sea compact macro port 111 info
Started by prince ahmed ·
  1. hi
    i already did search but could not find any answer...
    i have acquired the above port and have no idea what macro lens to use with it...
    i also have sea&sea D200 housing and NX Compact Macro Port Base with it,, i cant find any info about this port in the sea&sea chart....
    i hope someone can help me
    thanx
  2. macro port 111 is long flat port for macro lenses so you can use with nikon 105mm macro or similar.
  3. first thanx for ur reply,,
    what other options i can use,,, the problem that i sent an email to sea&sea but no reply till now,,,
    what other lens i can use?? can i use sigma 105 vr ,, or nikon 105vr, is it with the base or only the port is enough????
    all of this questions i need to know so i can buy the lens and start using it..........
    thanx again
