Sealux for Panasonic HS700 - any experience?
Started by wydeangle ·
  • 19Posts
  • 19Replies
  1. Looking for a small housing for the Panasonic HS700 and its close relatives. Anyone actually dived a Sealux or other compact housing for this camera?
    Tom
  2. Looking for a small housing for the Panasonic HS700 and its close relatives. Anyone actually dived a Sealux or other compact housing for this camera?
    Tom
    I was interested at this housing too but I couldn't find any information about its specifications.
    I placed an order on Seatool housing instead. There is no flip in filter but I love its small size and its ability to use WA converter inside the housing.
  3. Well that's interesting. I've searched, Googled and tried to find it, but there does not appear to be any Seatool housing available for any Panasonic video camera, kkfok.
    Is there some secret place we might find one for the Panasonic HS700?
    Tom
  4. Well that's interesting. I've searched, Googled and tried to find it, but there does not appear to be any Seatool housing available for any Panasonic video camera, kkfok.
    Tom
    http://www.seatool.net/list/TM700.html
    HS700, TM700 and SD700 are all the same except the kind and size of memory.
    Edited by kkfok
  5. 専用防水ハウジング
    Well THAT certainly explains it
    The question remains: have you actually dived this housing? if so, how did it work?
    Tom
    Edited by wydeangle
  6. 専用防水ハウジング
    Tom
    No experience yet. I just placed the order and I should receive it by the end of this month.
  7. OK - but please post after you do! I'd like to hear your experience.
    Tom
  8. I have received the Seatool housing already. It is very small and compact. Buttons on the grip simulate functions of the remote controller, send IR signals to the camera to provide the control.
    Here are the functions on the grip.
    1. ON/OFF Power
    2. Wide/Zoom
    3. REC
    4. PHOTO
    5. OK Button
    6. UP/DOWN/LEFT/RIGHT for you to surf through menu.
    Besides those buttons on the grip you only have access to the function button and the focus ring. For the focus ring to work you have to buy an extra (focus/zoom) gear.
    I don't have time to get it wet yet but I find 2 problems so far.
    1. There is no way to switch back to IA Auto mode once you switched to Manual mode.
    2. Resolution of the external monitor is not really good.
    Besides, there is no flip-in filter for this housing which I already know before I made my order.
  9. I hope you will find the time to share some flick with us.
    Bye
  10.
    Thank you for the photos. It looks very compact, and I see (I think) what you mean about the monitor. Still, it's better than the tiny viewfinder I use on my Canon HV30s.
    Some more questions:
    1) How is the balance and buoyancy? Can you let go of it underwater and have it remain where you put it? Or does it sink, rise or rotate?
    2) Have you any video footage from it yet?
    3) How are the wide angle shots?
    4) How is the macro?
    Regards,
    Tom
  11. I reopen the subterranean diatribe on the little panny tm/sd/hs700 green cast :)
    I found two videos on youtube shot on a wreck in the Adriatic sea in Italy, near Venice:
    Without white balance:
    http://www.youtube.com/watch?v=j5tzm-NZIVI
    White balanced in post (long version, diving part at the end):
    http://www.youtube.com/watch?v=DP7bi3LHaPQ
    Shots were uploaded in SD and the owner is a beginner. The water near Venice has always near green aspect and a poor viz.
    Anyway this video shows very well the tendence of this camera to exaggerate the green .
    Bye :D
    Edited by Long John Silver
  12. All the videos embedded:
    [vimeo]15239180[/vimeo]
    [vimeo]15226585[/vimeo]
  13. Thanks for the samples.
    Do you have any macro samples?
    Tom
  14. Thanks for the samples.
    Tom
    [vimeo]15325282[/vimeo]
    It has been converted to SD by Vimeo as I am not a plus member, for original quality you can download the original file.
    Edited by kkfok
  15. kkfok,
    Thank you very much for the macro sample. It looks quite nice!
    I think I need one of those cameras and housings ^_^
    Tom
  16. Thanks for the samples.
    Tom
    kkfok,
    Thanks for in information. What can you tell us about the housing in addition to what you posted above?
    1. What's the process for doing manual WB in the housing? How good is the auto WB underwwater?
    2. Above you said there is no flip-in red filter. Did you use an external one?
    3. Do you know of a US supplier?
    4. Anything else about the useability of this housing?
    Thanks!
  17. kkfok,
    1. What's the process for doing manual WB in the housing? How good is the auto WB underwater?
    Thanks!
    1. It is the same as doing that in the remote controller. If you have already done MWB once, you just need to press the OK button twice to do it again. I am still trying to figure out the best way to do MWB. I did several dives with this camcorder mostly with an external red filter. The results were usually good to very good when I use sand as reference and especially in the first 20 metres. For wall dives, I am still testing the best way to do MWB. My results were usually a bit too purple if I use a white slate as reference and too green if I left it at AWB.
    2. Yes, I am using an external one. If I use a dome I place a magic filter between my camcorder and the internal Wide angle converter.
    3. No idea for this one. Seatool USA? Reef Photo?
    4. This housing is very compact and so negatively buoyant.
