Hi All, I'm a Southern California retired professional diver with 5000+ dives, ex-instructor, writer & photographer just starting to take u/w photos again. I'm using a Nikon D60 in a Sea & Sea RDX housing with Nikkor 60 mm micro lens and flat port, plus Nikkor 10-24 wide angle zoom and dome port, twin Sea & Sea YS-110's. I've used it underwater about 25 hours, but it still takes me awhile to put the rig together, etc. On my most recent diving day I discovered, in the water at depth that the camera wouldn't fire because I'd left the lens cap on! I'm shooting manually, having some OK results even in poor vis, but looking forward to spending lots more time in the water. I'm finding the learning curve from manual film shooting to manual digital shooting to be longer than I'd hoped, and I'm not even at the editing stage yet. I'm looking for ways to see better, so I'm hoping for information on viewfinders I might be able to use on the Sea & Sea RDX housing; have a trip to Socorro planned and want to maximize the gear I'm using right now without bearing the expense burden of upgrading yet. I haven't gotten good enough to challenge this equipment - this photographer needs to get better before she gets a better camera.
- 11Posts
- 11Replies
Introducing myself
Welcome! Your experience will be welcome here, you can be assured of that – and so will your questions.
... and I wonder how many other WDHOF members we have visiting us here?
Wow that's awesome news - and great sleuthing Darren!
Welcome to Wetpixel! I'm not an expert in the RDX housing but if you're lucky you'll be able to add a Inon or Nauticam finder - ask Berkley White or Ryan Canon about it.
Hi there, i believe the Inon viewfinder fits on the Sea and Sea housings fairly easily. However, its a 45 degree one so certainly takes a lot of getting used to. I used it only once on a dive and i hated it. That seems to be the first reaction of most folks who use it, but after using it on several dives those same people don't want to go back to a straight viewfinder. IE: dont get frustrated right away, you will get used to it
welcome to WP
I am completely blown away by the WDHOF mention! How did you know?! Thanks for all the info on Inon, etc. alternatives, I'm checking into it on Monday.
Here's to you,
Erin
I am completely blown away by the WDHOF mention! How did you know?! ....
Erin, on the internet, there's no place to hide...
On the finder issue, unlike Mike, I'm a fan of 45 degree finders, having had one on my Seacam system. The two complaints about them seem to be :
1. the lengthy transition time getting used to them (unless you're an old Hasselblad 45 degree prism finder user from last century that is).
2. the extra thing on the to-do list when changing from one orientation to the other (horizontal-vertical or back) as you need to turn the viewfinder as well.
Oh for a square sensors!
darren
Unlike the Hasselblad it is not reversed left to right too!
45 degree finders off a comfortable viewing angle, particularly if diving in a drysuit with reduced neck movement. They are also excellent for getting low viewing angles, when the camera is on the sand (such as somewhere like Lembeh).
The main downside is that they are much harder to shoot straight up or straight down images than a straight viewfinder.
And as Darren says they take time to adjust. The best way to adapt to one is to take it on a week + dive trip (where you will be diving every day). Ideally this should be a wide angle trip - as they viewfinder is much harder to adapt to with macro (as aiming is much more difficult). Generally on days 1-3 you will hate it, but by day 3 you will stick admit you should stick with it. After that you really start to warm. It is also probably best to take it on a trip that you have done before - nothing worse than missing once in a lifetime shots because of it.
The final downside of 45 degree finders is if you have more than one housing. It is a real pain swapping between 45 and straight viewfinders underwater!
...Unlike the Hasselblad it is not reversed left to right too!
sorry Alex, I meant the 'blad 45 degree prism finder, the one which gave you an un-reversed "correct view" look at the focussing screen... was great when shooting square, but hopeless with a 16-on back!
What geeks we are!
darren
It took me about 10 dives to fully get used to my S45, now I cannot imagine diving without it!
It is a faff changing orientation so I tend to preset everything and only change if subject matter really demands it. In my experience its a bit like getting into a macro or wide-angle frame of mind, when the camera is set for vertical shots then I tend to look for and 'see' them more effectively.
What geeks we are!
You got it!
