WA Compact Flash compatible with Fuji S2
Started by cmm1970 ·
  1. Are any of you using a WA enabled card like the 1Gb Lexar 40x card with a Fuji S2. Does it require a firmware update to make it happen.
    Second question, If you are using a microdrive IBM or Hitachi(same card I think), are you happy with write speed with your S2?
    Thanks for posting replies!
    Mike
  2. The S2 does not have "write acceleration" built in. Only a few of the newer and "high end" cameras do.
    To see which CF cards perform best in the S2, see Rob Galbraith's media comparison page at www.robgalbraith.com
    I use a Viking CF card and a Microdrive.
    HTH
    James Wiseman
  3. I am using the Lexar 1 GB 32X WA card with a Fuji S2 with absolutely no problems, and no updates. As James said the S2 doesn't have the WA capability, but the card still works fine.
    Regards, Linda
  4. The Transend 1 GB 32X card works fine as well.
    Chris
  5. I am using a 2GB Lexar CF card with the S2 with no issues.
    M
  6. Has anyone used the Magicstor 2.2Gb Microdrive CF card in a Fuji S2? Drives over 2Gb need to be formatted FAT32, and it appears that the S2 only recognizes FAT16.
    Bruce.
