10.5 behind S&S Compact Dome NX
Started by aczyzyk ·
  1. Can I fit Nikkor 10.5 behind S&S Compact Dome NX without extension rings?
    Does it work fine optically?
  2. Can I fit Nikkor 10.5 behind S&S Compact Dome NX without extension rings?
    Extension ring is needed.
  3. Extension ring is needed.
    Which one? I have 40mm.
  4. Which one? I have 40mm.
    The 40mm should work but would suggest you confirm it with your local S&S shop. I was using mine with 56mm (Extension Ring 40) but have since move on to the optical dome port.
