Double TTL Strobe with Nikonos 5
Started by riodda ·
  1. I all, i've been diving with my old morris strobe and the 20mm and i think i may need a second light.
    I've found on ebay a cheap SB105 and now i need a cable to connect both the strobes to the nikonos.
    I can't put the SB105 as slave since it's slave mode is not TTL.
    Since the Morris has it's own conncetor different from the SB105 i need a Y cable with the sockets, but i didn't found any of them that allow TTL of the 2 Strobes.
    I've found this 2
    http://www.housingcamera.com/ProductDetail...storysingle=YES
    http://www.isotecnic-commerce.it/viewImg.p...;id_prodotto=81
    But both looks like are non TTL.
    Thanks, Best Regards.
  2. Try looking up Heinrichs Weikamp, i used modified connectors on a housing with their inexpensive bits. They're in Europe too.
