Tokina 10-17mm vs Nikkor 10.5mm
Started by Aussiebyron ·
  1. Hi All,
    I had the chance to borrow a friends brand new Nikkor 10.5mm Fisheye so I can compare it with my Tokina 10-17mm Fisheye. I basically shoot alot of Grey nurse sharks and thought I take the opportunity to comapre the two lenses with the subjects I shoot. I used my Aquatica housed D90 with 2x Ikelite DSD125's.
    I noticed straight away that I had to shoot at say f7.1 for the Nikkor 10.5mm when I would normally get the same shot with the Tokina 10-17mm on 10mm at f8.
    Is there a review somewhere comparing the two lenses in a more techincal format than just my observation?
    Any others opinion/observations between the two lenses?
    will try an post some pics later.
    Regards Mark
    Edited by Aussiebyron
  2. I did see the review of the two lenses back in 2007 by Stephen Frink. Which made me wonder if anyone else has observed any simialar observations which I have made between the two lenses?
    Regards Mark
    Here are some examples with the Nikon 10.5mm shot at f8 1/100th. I would normally shoot these guys at f8 1/160th with the Tokina
    Regards Mark
  4. Hello Mark,
    I have both lenses so I can tell you my findings.
    First the Nikon 10.5mm is a little wider than the Tokina at the 10mm end.
    The Nikon has a little more fisheye effect. This can be seen in the viewfinder.
    The sharpness is not comparable. It's like a Nikon 18-70 vs Nikon 17-55.
    For me the Nikon is more contrasty than the Tokina. But on this point it's hard
    to compare.
    For you exposure change, I suspect the Nikon to be better taken into account
    by the metering system. In aperture mode (Average Matrix measure) with the
    Tokina (plain water subject 1 or 2 meter deep sun at noon) I ended up with
    -2EV compensation whereas with the Nikon it was spot-on. Don't know for
    deeper subject.
    Regards
    Stéphane
  5. Silly question - which one is sharper? I have not used either one and have very limited wide angle experience.
  6. Hello Mark,
    to compare.
    deeper subject.
    Regards
    Stéphane
    Hi Stephane,
    Thank you for your reply. I also noticed that the 10.5mm was a little bit wider than the Tokina @ 10mm. Noticed mainly with backscatter in the far corners when shooting with the 10.5mm in really Green water. You can see slightly in the shots I have attached above in green water (6-8m vis).
    Unfortunately my subjects are normally at 20m mark so I only really can give my observations between the two lenses based at this depth. Hopefully I can play with lens more in summer clear water here with Manta's and Leopard sharks. Which I can shoot at 12m or so but in gin clear water.
    Regards Mark
