3D Driving Test - Smooth Cam
Started by shawnh ·
  1. [vimeohd]14232173[/vimeohd]
    Continuing to experiment with topside rig and workflow.
    How do you smooth a left & right clip pair?
    -Turned of steady shot on cameras (feared asynchronous steady movement would look like wobbly eye-balls)
    -Did not stabilize source clips (because stabilization would likely not be applied uniformly to left and right clips) - will test this one out.
    -Footage was interlaced so had to de-interlace source first
    -Synched and coupled clips
    -Applied geometry and convergence adjustments
    -Exported as anaglyph 3d FCP quicktime file
    -Brought back new clip into FCP timeline
    -Smoothcam filter on de-interlaced 3d clip
    -Render and export again as anaglyph 3d FCP quicktime file
    -Compress using Turbo HD
    Gotta love 3d workflow :crazy:
  2. This doesn't really work for me, Shawn. I want the background to be diverged, and it doesn't really seem to be diverged. I think the cameras need to be further apart.
  3. Yeah probably. This clip lacked proximal subjects to make it pop more. I have others that are much more 3D. Just digging through now.
