Slight Horizontal Banding on DVD
Started by peterbkk ·
  1. I'm having a slight problem with some footage that I've edited and now trying to compress to DVD. In scenes with dark gradated water background, I am getting very slight horizontal banding on the DVD version when displayed on my 40" Sony TV. Just in the dark blue water areas.
    The problem can NOT be seen in FCP, on my Mac using QT and H.264, on the youtube version (http://www.youtube.com/watch?v=sUKFYMlKiNo) or in the Bluray version on the same TV. But, when I play the DVD on my new 40" Sony flat TV, the horizontal banding can be seen. It is slight but annoying.
    I've never had this problem before and I was using the same compressor setting that I've always used to make DVDs. The settings are shown below.
    Does anyone have any ideas how to solve this problem?
    I've just started another Compressor (3.5.2) run with Deinterlace filter set to Best to see if that helps.
    Regards
    Peter
    Name: MPEG-2 16:9p Better
    Description: HQ 30 mins DVD-5 Progressive
    File Extension: m2v
    Estimated size: 357.03 MB
    Type: MPEG-2 video elementary stream
    Usage:SD DVD
    Video Encoder
    Format: M2V
    Width: 720
    Height: 576
    Pixel aspect ratio: PAL CCIR 601 (16:9)
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Selected: 25
    Frame Controls On:
    Retiming: (Better) Motion Compensated
    Resize Filter: Linear Filter
    Deinterlace Filter: Better (Motion Adaptive)
    Adaptive Details: On
    Antialias: 0
    Detail Level: 0
    Field Output: Progressive
    Start timecode from source
    Aspect ratio: 16:9
    Field dominance: Progressive
    Average bit rate: 6.8 (Mbps)
    2 Pass VBR enabled
    Maximum bit rate: 8 (Mbps)
    High quality
    Best motion estimation
    Closed GOP Size: 12, Structure: IBBP
    DVD Studio Pro meta-data enabled
    BlackWhite Restore
    Black: 5.000
    White: 0.000
  2. Hi Peter
    Are you using the same version of compressor as before or is this a newer version?
    Whats the DVD look like on another screen?
  3. Hi Peter
    I can't remember when I last upgraded Compressor but I think that it was a while back. I upgraded FCS not long after it was released. I'm sure I've done DVD compressions with this version without this problem.
    I have not seen it myself but I gave a copy of the DVD to a friend and she said she could see the banding on her TV too.
    I've thought about what could be different about this video but haven't come up with anything conclusive. The only new element is the video camera (from Sony HC3 to Sony 550VE), but, as I mentioned, the banding is not visible on any other version accept the mpeg2 for the DVD.
    Regards
    Peter
  4. Bummer....
    I would try another encoder and encode out a MPEG2 file and see how that looks.
    Not on a MAC here but I know on a PC not all encoders are the same, just because its a big brand name does not mean its a good encoder.
  5. Bummer....
    I just got home and the Compressor run with Deinterlace filter set to "Best" has finished (took 7 hours to produce 7 minutes of mpeg2 video).
    The result is much better. The horizontal banding is gone. You can see some gradation banding but very very slight and only in scenes where the colour goes from very dark blue in the bottom to very light blue in the top. I'm guessing that the 576 vertical pixels of SD just can't cope with that much gradation smoothly. The Bluray version with its 1080 vertical pixels is so much better.
    Regards
    Peter
