FS - FIX UWL-04 Fisheye Wet Mount Conversion Lens - 67mm/52mm (NIB)
Started by mcliffy2 ·
  • 13Posts
  • 13Replies
  1. Brand new, still in the box FIX UWL-04 Fisheye Wet Mount Conversion Dome Lens (67mm/52mm). This will work on either 67mm or 52mm mounts. I bought it to use with my G9 setup, but decided to switch over to a DSLR before I could use it, and its now too late to return it to Reef Photo & Video, so my loss is your gain. I'll take $375 shipped.
    Here is the stock photo from Reef Photo & Video...I can get pictures of the actual lens on request.
  2. 1. What is the measure of the width of the lens glass (ie, the measure of the glass part itself, not including the metal around it) at the back of the lens (the part that faces the camera port)? The width in "mm" would be best to know, but inches are fine if farily accurate. Thanks - I hope you can answer this.
  3. can i use this lens on ikelite G9 housing?
  4. can i use this lens on ikelite G9 housing?
    Yes, it works on a G9 housing. Because of the 67 to 52 mm conversion, you have to zoom in a bit, so its not quite as wide as it would be on a smaller mount, but is wider than the Inon UWL-100 that I also have.
  5. 1. What is the measure of the width of the lens glass (ie, the measure of the glass part itself, not including the metal around it) at the back of the lens (the part that faces the camera port)? The width in "mm" would be best to know, but inches are fine if farily accurate. Thanks - I hope you can answer this.
    I cannot find this information online anywhere, so I'll have to measure it when I get home tonight.
  6. bump, still available. I'm willing to entertain reasonable offers.
  7. Yes, it works on a G9 housing. Because of the 67 to 52 mm conversion, you have to zoom in a bit, so its not quite as wide as it would be on a smaller mount, but is wider than the Inon UWL-100 that I also have.
    Sorry but can you elaborate on this point?
  8. Sorry but can you elaborate on this point?
    The 52mm thread is narrower, so at a wide angle you have to zoom in slightly or it catches the edges of the lens and you get a circle effect. You have to do this on the Inon UWL-100 as well, but to a lesser extent.
  9. The 52mm thread is narrower, so at a wide angle you have to zoom in slightly or it catches the edges of the lens and you get a circle effect. You have to do this on the Inon UWL-100 as well, but to a lesser extent.
    I suppose the point I don't understand is why a narrower thread translates into the above.
    Does the 52mm thread place the lens farther away from the housing?
  10. I suppose the point I don't understand is why a narrower thread translates into the above.
    Smaller circle for light to pass through to get to the lens, so you have to zoom in a bit so that the inside of the lens is not captured in the frame.
    Edited by mcliffy2
  11. Hey Mcliffy2,
    I'd like to make an offer on the lens, if still available. How would you like to proceed? Thanx...
    Edited by ozdiaz
  12. Hey Mcliffy2,
    Just sent you a message in response.
  13. Sold.
