YS-90 DX and G11
Started by Alastair ·
YS-90 DX and G11
  1. I am looking at the Fisheye housing for my wifes G11 - i have a YS-90DX that i used to use and is still in good condition - can it be used with a fibreoptic cable from the Fisheye (or any) housing? I want to replace it with a Inon later but just to get going.....
    And if i do use it with fibre optic will i get TTL exposure?
    thanks..
  2. Yes - you could use this with the G11. The strobe just needs to be switched to SLAVE ON.
    No - you wont get TTL with this combo.
  3. ok thanks.
    For TTl exposure is there a recommended strobe? Inon 2000 or Z240?
  4. ok thanks.
    My wife likes her dual S&S YS-01s with the G10/Fix. She was going to get the Inon S2000, but then S&S released the new YS-01 strobe and it has built in focus light which the S2000 does not.
  5. The Inon D-2000 has a built-in focus light, automatic mode, 2 strobe tubes and work perfect with the G11.
    Chris
  6. thanks all...
    until bonus time (if) i will still be using the YS-90 - how do i attach the L-connector on the fibreoptic cable to the slave sensor on the fornt of the flash?
    thanks again..
