Canon G12's fitting in G11 housings
Started by RchardRigby ·
  1. Anyone have any info on this subject.
    Basically I have Fix housing and G11 which I like very much and considering buying a back up G11 before it becomes obsolete.
    But a few internet boards etc seem to indicate that the G12 will fit in G11 housings.
    There is a front control dial which is, new the rest looks the same.
    Any thoughts and info will be appreciated.
    Cheers Rich
  2. As far as i heard the camera body is the same so the G12 should fit in the G11 housing.
    The cameras are the same except that the G12 has the front ring dial, what you can't use
    with the G11 housing. As the FIX housing is extremly precise and slim there may be some problems
    with this particular housing and the front dial, while in a "bigger" housing the camera should fit.
    Now the big question is if you need the front dial to use the camera or if you can still use it without.
    Honestly, i don't see too much differences between both to change my G11/Patima rig.
    Chris
  3. I haven't seen the G12 yet but if the front ring can be set to aperture and the rear dial shutter speed, that's a big bonus imo.
    The G11 housings won't have this function even if they fit.
    It was a tough call for us between the G11 & S90 for this reason.
  4. Sorry to bust your bubble but the G12 will not work in the FIX G11 housing. The front dial sticks out and prevents the camera from laying flat when installed in the housing. You can close the door to the housing, but I'm too nervous to actually submerge it due to the extra force required to close the door. Because of this the zoom doesn't function and neither does ISO or mode.
    The Canon OEM housing works fine as there is extra space in that area of the housing and the front dial is well clear of the front. It's almost as though they knew when they were making the housing for the G11...
  5. The G12 may fit the Patima G11 housing as it's not so extrem precise and tight fitting as the FIX G11 housing.
    Anyway, switching from G11 to G12 and not being able to use the front dial makes no sense to me if i'm not able to change ISO, zoom and Mode .... I rather stick with my G11 or wait if a G12 housing will be available.
    I would like also to see some pictures from both cameras to verify the quality differences between both cameras.
    Chris
