lens for canon 450d
Started by dvrdve ·
  • 13Posts
  • 13Replies
lens for canon 450d
  1. if u had to buy 1 U/W lens for a canon 450 in a ikelite housing with a ds125 strobe what lens would u buy?
  2. if u had to buy 1 U/W lens for a canon 450 in a ikelite housing with a ds125 strobe what lens would u buy?
    For me would be Sigma 10-20mm HSM. i think it's just thin enough to fit, but it's been a while since i owned an Ike housing so check first.
    Roddy
  3. Tokina 10-17mm FE
  4. In my humble estimation the Tokina 10-17mm FE is the best wide angle lens available for the cropped cameras. Then I'd save my pennies for the 60mm macro.
  5. would the autofocus still work with the tokina
    thanx a lot for the suggestions
  6. would the autofocus still work with the tokina
    Before suggesting a lens, I would ask if you have a port already. :D That could influence the lens choice.
    Assuming you don't already have a port for the Ikelite housing, are you more interested in Wide Angle or Macro?
    The macro lens and port will probably cost less than a WA/FE lens and dome port.
    I have both the Tokina 10-17 and the Canon EF-S 60macro for my T2i. I can't imagine having just one or the other. But if I could have just one it would be the 60 macro. Maybe.
  7. i have a 6inch port -which takes the factory std 18-55 lens with which i have had some good stuff
    ports seems cheap compared to the lenses
    do yourself a favour check out Rowley Shoals of the north west coast of australia 26-28 deg c 80 m viz depending on tide it can be more- kid u not
    heading back there again
    onewolf
    "I have both the Tokina 10-17 and the Canon EF-S 60macro for my T2i. I can't imagine having just one or the other. But if I could have just one it would be the 60 macro. Maybe"
    my problem is that i would most probably have to get another camera to get a macro setup for as there is too much too take with a single setup - but i couldnt afford that
  8. would the autofocus still work with the tokina
    Yes, very well.
  9. ordered a tokina 10-17 thanx
  10. had not even considered macro was assuming you meant WA. However i have the 60mm macro as well and it's a fantastic lens in general not just for macro. have used it for some good small fish shot's ( under 12" long)
    it will also fit in the standard port as it's almost exactly the same size as the kit lens.
    Roddy
  11. well the tokina got here today
    at almost half the price than the shops wanted
    from digital world international in 3 days yeaah
    even better it fits my 6" port perfectly
    will most probably get flooded on the 1st dive as i ve used up me good luck it feels
    cant wait to get it UW
    thinking seriously about a 60mm macro now as i have a lil bit of $$ left
  12. will most probably get flooded on the 1st dive as i ve used up me good luck it feels
    No negative waves partner, Neptune will hear you. ^_^ Recommend you pour a little rum over the housing before the first dive as a offering to the gods. That and a little practise in the pool before you go will go a long way. You're going to need to be much closer than you have been used to with the 18-55.
    Have fun!
  13. steve housing has about 100 dives to it- so i ll have the rum myself
    taking some micro mesh with -cause i can see im gonna scratch the port
    trying the lens above water i have been touching the port to stuff
    -cant believe how close it focus
    tahnx for all the advice saving for the 60mm
