Hi,
I'm hoping people can share some wisdom with respect to video cameras mounted on DPVs. Specifically I'm interested to hear if people have an issues with one mounting solution over another. Two that I'm look at are the Dive-Xtras and Silent Submerge mounting systems.
Hi Betty,
with my team we use the SS system and it's really a nice piece of equipment. I do not know the other. We used the SS mainly on Zeuxo and Gavin scooter.
In addition to a video platform, I'd like to use the DPV as a transport at to make life easy when shooting stills. ie. I'll just mount the camera to the dpv for tec dives and remove it for shooting. As such I consider ease of connect/disconnect to be a key feature.
We tried it many times but definetively it's not worth. While, on the SS, the quick disconnect feature is well designed, it's really a pain in the ass doing it at depth for each shot. You take a picture... then you want to move a little forward for a better spot/composition... Likely you find yourself swimming with the camera in one hand, the scooter in the other, two stages etc...
I also imagine it'll do horrible things to the trim of the scooter, so I assume buoyancy of the housing and light canisters will be key to success.
Another problem doing connect/disconnect underwater is that you have to set the buoyancy perfectly for the housing and the scooter (with the mounting). With a scooter like the Gavin this is another pain... Furthermore it's very difficult to set neutrally buoyancy some housings. You could need extra weight or buoyancy devices and the whole thing becomes really too bulky for my taste.
Speaking of camera, it was really a hard task setting the trim and buoyancy on a Seacam housing with arms and flash. About camcorders... It depends on the model. We shot a lot with a Z1 with Phenom housing on a gavin scooter.
Most of this videos are shot with this setup:
http://vimeo.com/user288350/videos
That housing its perfect for these applications because normally it's positive and then with its weight become perfectly neutral.
Gates housings for the same camcorder are a pain in the ass because they start negative and then you have to add bulky buoyant bars...
The best thing wold be a very compact set. A Phenom mounted on a Gavin Scooter its a nightmare for travel and boat trips but it's the best set for tek diving.
If the budget it's not a problem, maybe with the new VidDSLR camera you get the sufficient low light sensitivity for deep diving.
Any others points would be much appreciated? e.g. lens choice, travel speed when shooting video, etc...
Slow speed and if you dive on wrecks then you need the widest lens available like on Amphibico Phenom or Phatom lens on Gates. Usually when you shoot video you stop and you use the added stabillity of the whole thing (scooter and housing).
Keep attention that on some new scooters has a very thin diameter and they are very light so choose the housing accordingly.
