Kenko 1.4 + 10-17 good for sharks? Which ikelite port?
Started by bloups ·
  1. Hi Everybody
    I have been using both the tokina 10-17 (6" and 8" dome) and the 12-24 (8" dome +2diopter) for sharks in polynesia. I am really happy with the results of the 10-17 except that most of the sharks are a bit too shy and the lens is too wide. I havent been so happy with teh sharpness of the 12-24 and I was thinking to use the Kenko 1.4 converter with the 10-17 for my next trip.
    Is that a good idea? Any experience with the combo for sharks amd other large fish?
    I am using a D200 in a ikelite housing, what port is suitable for this combo?
    Thanks for your help
    Galice
    www.galice.nl
  2. I would be worried that images at 17mm with a teleconverter might be a bit soft: I know that it's a platitude, but getting close (ie getting in the right place, possibly with the right people) is better than a longer lens...
    The 12-24mm is notorious, and needs a really big dome to perform merely adequately. I can't say anything useful about Ikelite domes, but I'm sure that there's someone here who knows...
    Tim
    Edited by tdpriest
  3. Try a +4 diopter on the 12-24. I use it in a Nexus with 6.75" dome. Works great.
  4. I took this with the Tokina 10-17 and the 1.4 teleconvertor in Gran Canaria last week, on a Canon 7D in Nauticam Housing
    and then this on the same dive focusing about 2cm from the end of the Zen 100mm dome port
    Very versatile combination I have found.
  5. Try a +4 diopter on the 12-24. I use it in a Nexus with 6.75" dome. Works great.
    Ditto on the 12-24 +4, but I am favoring the 10-17 or 10-17 + 1.4 TC and the small Bare dome for travel.
    Bob
  6. Thanks
    Any suggestion on which ikelite port for the combo with the 1.4 converter ??
    Galice
    www.galice.nl
  7. Same port you use with 10-17 should work, but add a 20mm extension ring to maintain lens/dome relative position. (20mm is approx height/width of 1.4 TC)
