teleconverter in a subal housing
Started by DuckPhat ·
  1. Hi all
    I am about to purchase a Kenko Teleplus 1.4X Converter for my D70
    I am going to use it with a 60mm lens however i was wondering if it would fit inside my flat port FC-60
    also will i able to use the autofocus on the lens when coupling it with the teleconverter
    any info would be appreciated
    cheers
    craig
  2. Hi all
    cheers
    craig
    You certainly should be able to use the autofocus on the 60, any lens faster than f4. As for fitting, I suspect that you might need a short extension ring depending on how close the 60 is to the front with that port. On the Canon side, you need a short extension ring.
    Bill
