Member Introductions / Archived topic
Basic DIY Housing
Started by andreaso ·
Basic DIY Housing
  1. Hello
    I am certainly new to this field of photography. I am in a research phase of investigating building a basic sealed housing for photography that will essentially be remote (fired remotely) in a wet environment. This will not be for diving but for floating on/in water bodies primarily for nature photography.
    Idea is to build a simple aluminium housing with dome port (7d + 16-35mm at this stage). Issues surrounding firing (rf) and controls is certainly still in infancy and not yet investigated thoroughly. This needs to be a robust housing whereby acrylic will not suffice so an "old" second-hand housing is not suitable.
    I am currently trying to find info on port mounting options (parts required) to fix to an aluminium housing.
    Can anyone provide links / ideas / recommendations to this type of information or similar project with pictures etc for design considerations. Also ideas for remote firing eg Pocket Wizard experience - understanding that rf will not transmit through aluminium.
    thanks in advance
    A
