Help on Ikelite Sub Strobes
Started by nivla80 ·
  1. Hey all,
    Apologies if this is a stupid question..
    I recently purchased a pair of DS-160's.. My question is, if I want to use the strobes in full manual mode, (i.e adjusting strobe outputs indiviually on each strobe), how do I do that? On the strobe itself? Or the housing conversion circuitry? I'm currently shooting a 5D2 in an Ikelite housing..
    When the housing circuitry is set to manual, I get to adjust the flash output there, but does it asjust output for BOTH strobes, or just the master?
    Completely lost as to how to manage this..
    Thanks for your input in advance!!
  2. Leaving the strobes on TTL will allow you to manually adjust the strobe power from the buttons on the housing (once you have selected manual mode on the housing buttons of course). In this case both strobes will fire at the same power; the slave will just echo anything the master does
    If you want to fire the strobes at different powers then you need to use the manual controls on each strobe. In this case it doesn't matter what the housing is set to. Its just a synch fire signal and any quench signal from the housing will be ignored by the strobes.
