Hi Guys & Gals,
I have a d700 in a Nauticam housing with a 8" dome attached. I am fairly new to photography and am having lots of problems with strobe aiming and flare with the 15mm fisheye lens. I don't know how to overcome this problem. I have attached a photo which shows the flare I am getting. I am sure I have tried just about every angle with the strobes from as wide out as I can get them, higher, lower, pointed away from subject, pointed slightly in and nothing is working properly.
It is also obvious from the photo that I am not lighting up the middle of the frame but as soon as I turn the strobes in it becomes worse.
I have 2 z240 Inon strobes. I am using the camera and strobes in the Manual mode.
Does any one have any suggestions? I am kinda putting the problem down to it being a combination of a large dome, a full frame camera and wide lens. But everyone says this is a great set up. I just can't get it right.
HELP!!!!!
Deb
