Northen water
Started by MAstiff ·
Northen water
  1. Heysa
    I dive mostly in Denmark, where dark water and short sight (0.5 to 10meters) is normal. I´ve got a Olympus c-5050 and i´m wondering wether to use permanent "video light" or to use a flash? Enyone inhere have expirience of fotographing in "Northen water" :ph34r: and therefore can conclude wether permanent light (and what type of light then) og a flash (and what type of flash)?
    Regards Jens
  2. Jens,
    I would recommend strobes for 2 reasons. For one, in order to get more than a black background, you will have to increase your exposure time to a point where you risk blurred pictures. The short strobe flash will make sure your main objects are sharp.
    Secondly, in dark waters, a permanent bright light tends to scare your objects away.
    Michael
