LR3 Noise removal question
Started by Scubysnaps ·
  1. Hi guys,
    When I look back at an image with noise reduction used on LR3, it only seems to exist when I zoom into the image, when I show the image full, it appears present. Has anyone else noticed this and knows of a way to show it with noise reduced at all times?
  2. Hi guys,
    Is this in the library module or develop? I have noticed that when I return to library module the views do not always update. Try generating previews again.
    Duncan
  3. Thanks Duncan, its in Develop..at least...how do I generate previews again?
  4. Thanks Duncan, its in Develop..at least...how do I generate previews again?
    From the Library module, LIBRARY > PREVIEWS > GENERATE PREVIEWS (just pick either standard or 1:1)
  5. From the Library module, LIBRARY > PREVIEWS > GENERATE PREVIEWS (just pick either standard or 1:1)
    Thanks Sean, I'll try that tonight :)
