Is this right for my gear?
Started by Jasoncassanova ·
  1. My aunt from the states is giving me a pelican case for my gear, she'll be bringing it over soon. Now I just want to know if this model would be the right one for my G11 Ikelite set up, 2 DS-160 strobes, ULCS regular and bouyancy arms, Dome lens, Macro lens, etc.
    Pelican 1554
  2. My aunt from the states is giving me a pelican case for my gear, she'll be bringing it over soon. Now I just want to know if this model would be the right one for my G11 Ikelite set up, 2 DS-160 strobes, ULCS regular and bouyancy arms, Dome lens, Macro lens, etc.
    Pelican 1554
    Should be fine, if a little bit big for that setup. It is 18 inches x 14 inches x 7 inches or 48x36x20 mm so you should have room to spare.
    Bill
  3. Should be fine, if a little bit big for that setup. It is 18 inches x 14 inches x 7 inches or 48x36x20 mm so you should have room to spare.
    Don't you mean, "so you have room to grow when you decide to get more camera gear"?
    :P
    -Gina
  4. I use a Pelicase for my G11 Patima housing with 2 ports, 1 D2000 strobe, 1 UWL-100 wetlens, 1 Fantasea flexarm and tray and minor spare parts.I guess that it would be too small for your 2 DS-161 strobes.
    I strongly suggest that you get a Pelicase with a size not exceeding cabin luggage measure as this will save you a lot of nerves,
    as you can take your baby with you and not as checked baggage.
    Your rig should fit in one of this size cabin trolleys but you may have to eliminate the foam/dividers inside as this will free a lot of space.
    This for example: http://www.bhphotovideo.com/c/product/5633...y_On_Case.html/
    Chris
    Edited by ChrigelKarrer
  5. Sadly, Pelican cases have been targeted in some parts of the world as air-side thieves know that they contain valuable stuff...
    Tim
    :P
  6. I use a Pelicase for my G11 Patima housing with 2 ports, 1 D2000 strobe, 1 UWL-100 wetlens, 1 Fantasea flexarm and tray and minor spare parts.I guess that it would be too small for your 2 DS-161 strobes.
    Chris
    hi chris,
    i don't quite get what you mean... the model of the case i showed is bigger than the case you are suggesting... do you mean that i should get the 1510 rather than the 1554?
  7. Sadly, Pelican cases have been targeted in some parts of the world as air-side thieves know that they contain valuable stuff...
    Tim
    :P
    when i get mine, i'll install a cuff and chain :)
    -Gina
    better roomy than sorry :)
