Ikelite G9 system for sale (in the UK)
Started by Timmoranuk ·
  1. I have two identical Canon G9 Ikelite systems for sale. Both are in used but good condition and have many bespoke and customised accessories.
    *** NB. The cameras are not included but good second-hand G9's are readily available on Ebay for around £100 - £150 ***
    Each system comprises (Cameras Underwater retail price):
    * Ikelite G9 housing including single strobe tray #6147.09 (£531.71), on-board flash diffuser and on-board flash block.
    * Ikelite twin strobe tray #9523.32 (£64.99) and two ULCS 1” ball strobe arm connectors #BA-IK (£39.98)
    * M67 Short port #9305.92 (£89.99) for wide angle lenses (necessary for the UWL-100)
    * INON UWL-100 type 2 M67 (£339.99) 100 degree field of view wide angle lens
    * INON dome port for UWL-100 - increases field of view to 130 degrees (£454.99)
    * INON UCL-165 M67 close-up lens (£159.00)
    * INON optical D cable cap set (£39.99)
    * Custom delrin fibre-optic strobe cable mount accepting both INON cap set and Sea & Sea strobe cable connectors. Makes using twin strobes very easy.
    * Custom aluminium accessory tray including; two custom delrin mounts for 1 watt Aquastar lamps (the lamps are not included but check them out here: LIGHT Aqua-Star LED - Divernet ) and custom machined aluminimum tripod mount
    * Aquaphot / KMR audible and visual flood alarm, fitted
    * Misc. Ikelite housing spares
    Total retail - £1720.64. I'm thinking of £500.00 for each system.
  2. I just have the G9 at present. Does this Ikelite case allow for use of the standard G9 telephoto lense? Is this gear still available?
