Use of wet diopter
Started by Yoav Lavi ·
Use of wet diopter
  1. (subsee or macromate) on a dome port - is it possible? have anyone tried it?
  2. I doubt there would be any point. Have you got a particular idea in mind?
  3. I doubt there would be any point. Have you got a particular idea in mind?
    Yes. I use sigma 17-70 as my regular lens in ikelite 6" dome port, and I am not happy with the "macro" capabilities of this setup. I was thinking that a subsee might improve things.
  4. Yes. I use sigma 17-70 as my regular lens in ikelite 6" dome port, and I am not happy with the "macro" capabilities of this setup. I was thinking that a subsee might improve things.
    Since the image in the domeport is virtual and the goal of the wet diopter is to increase magnification of the real image, I think it will be problematic. I don't have my lens software handy but at 70 mm if it worked the same as on a flat port (the assumptions are wrong for easy calculation though) you would get negative magnification at the short end of the lens and about 1.3:1 at the long end if my back of the envelope is correct.
    Bill
  5. Yes. I use sigma 17-70 as my regular lens in ikelite 6" dome port, and I am not happy with the "macro" capabilities of this setup. I was thinking that a subsee might improve things.
    I have a lot of respect for the Subsee, its a great piece of gear, just not the right tool for the job at hand, do you have a close up lens on the lens itself at the moment (Ikelite suggest using a +2) this alone would allow the lens to focus closer than it is at the moment.
    Edited by Viz'art
  6. I guess it is more about using the lens within it's limitations. You'll never be able to get supermacro with it but I found it very good for small subjects in their environments.
    On the same dive at Ras Mohammed, I was able to take this at the 17 end
    and this at the 70 end
    This second shot shows as much magnification as I was able to get using the lens and as close as I could get without harming the marine environment. The real beauty of this lens for me is the close focusing, I don't think that adding another diopter to get closer focusing would have been beneficial in this case as with the large dome I wouldn't have been able to approach the subject any further in any case.
    (these were taken with a 7D and the older 17-70, non-HSM lens behind an 8.5 inch acrylic dome)
    My humble advice then is to ignore anything very small when the 17-70 is on and work within the limitations of the lens.
