Quick Decision on Wide Angle
Started by TightLines ·
  1. I'm a long time reader but first time poster.
    A very quick last minute question for you guys:
    I'm leaving for Thailand in exactly 1 week (5 day liveaboard) and am debating picking up a wide angle wet mount, specifically the FIX UWL-04.
    I had been waiting to hopefully find a used one come up either here or SB but haven't had any luck.
    Current setup is an S90 in an Ike housing with 1 S2000.
    Possibly the biggest issue is that this will be my first time using a good underwater rig (something capable of taking good photos).
    Now, in your opinion would it make sense to pick up a wide angle lens or stick with the basics and get a feeling for the new rig while on the trip.
    Since UW is practically new to me would this be overkill?
    Thanks for your help and safe diving.
  2. I'm a long time reader but first time poster.
    My wife shoots the s90 in a fix housing - with the uwl-04. It is a good lens, fairly easy to shoot - I think you would enjoy using it. A single s2000 is not going to light that lens very well; so you either need to shoot natural light in shallow water (with good vis and sunny day - probably do ok to maybe 20-25 feet, but reds will be suppressed even this shallow), or maybe some close focus wide angle if you aim your strobe carefully at the subject. A second strobe (or at least a more powerful wider coverage strobe like a Inon 240) would be very nice.
    Also - Thailand will have lots of very nice macro subjects. An external closeup lens would be useful as well.
  3. I'm a big fan of fisheye lenses for compact camera users, I don't think you will regret it. Both Fisheye and Dyron make high-quality fisheye lenses for your setup. I haven't seen used ones for sale very often.
    Scott
  4. I use the INON 100 WAL with adapter rings on my S90 & Fix system. The advantage is you can take it off u/w but it does vignette some at widest (just zoom in one step). The con is its not as wide as UWL. I think it would be easier to learn very w/a photography on it?
