Crazyglue underwater?
Started by softnuance ·
  1. I want to repair a crack on my diving lamp (plastic) ... will Crazyglue hold at 60 feet underwater?
  2. I want to repair a crack on my diving lamp (plastic) ... will Crazyglue hold at 60 feet underwater?
    I don't know if crazyglue will hold but i would use 3M 5200 or any other similar poliurethanic bonding maybe
    with some wraps of self vulcanizing rubber tape over it .
    I use this to do watertight joints on the power cable feeding my well pump what is approx. 60 ft. under water for years now.
    You should use the special formulated crazy glue for plastics Krazy Glue Plastic Primer to bond and strenghten the parts together and
    cover it then with a layer of 5200 to seal it better.
    Chris
    Edited by ChrigelKarrer
  3. Ditto 5200. It will last forever too.
