D7000 Nauticam measurement please!
Started by PeteAtkinson ·
  1. Anyone with a D7000 Nauticam, could you put the camera in the housing without a lens and measure the distance between the surface of the lens mount and the external surface of the port flange. It will be around 36mm but a precise measurement would be great. Thanks!
  2. You are very close! It is 35.5mm.
    Edward
  3. Many thanks Edward. Aey has emailed you a number of questions; principally, with the 9" glass dome, will a Sigma 8-16 be vignetted by the dome mount when set up with the centre of curvature of the dome at the apparent front entrance pupil of the lens. The entrance pupil is 73mm from the lens mount at 8mm (65.8 at 16mm as close as I can measure it) and the angle of view is about 120 degrees. You can email me at yachtvigia@hotmail.com if you prefer.
    Looking forward to the housing!
