Drysuit with Extras
Started by dhaas ·
Drysuit with Extras
  1. Photos below of a great shape Diamond Trilaminate Dry Suit for Sale. I acquired it and just won't have time due to travel to make good use of it.
    Stock size LARGE, boots 9-10. I'd say up to 210 lbs. depending on build but I fit in it at 180.
    I had NEW long cuff (thicker near sleeve for dry glove ring use) wrist seals and a NEW neck seal installed and it was tested = no leaks
    SI Tech inflation (standard BC inflator type connector) and variable exhaust valve.
    This suit also has the heavier grade BDM zipper which Diamond only uses.
    Included is a lightly used Large size undergarment, fleece lined approximately 200Gram thickness.
    Price - $700.00 plus actual shipping.
    I also have an inflator hose I'll throw in.
    Email any questions directly.
    David Haas
    330-678-0591 phone
    davidhaas@sbcglobal.net
    post-244-1297528797.jpg post-244-1297528825.jpg post-244-1297528846.jpg post-244-1297528855.jpg post-244-1297528869.jpg
