FS: L&M Bluefin HD Housing HC1 and Sunray Lights
Started by gascubasteve ·
  1. FS: L&M Bluefin HD Housing HC1 and Sunray Lights - $3200 or make an offer
    Includes:
    L&M Bluefin Housing
    Sony HDR-HC1 HD 1080i Camera
    2x SunRay 21-watt HID Lighting Heads and
    2x Battery Pods
    4x Light Batteries (10.8v)
    Camera Tray
    2x Sony NP-QM71 Camera Batteries
    3x DVC Tapes
    Tokina 37mm wide angle lens
    2x L&M Multi-Chemistry Chargers
    Sony Battery Charger for Camera
    Also available but not included:
    110 degree Super Wide Angle Lens (See This Site for Details) - $2500
    L&M Macro Lens - $350
    L&M Remote Monitor w/ camera and Light controls - $1400
    Add 3% for any paypal transaction....
    email me : gascubasteve at gmail dot com for more info and detailed pics
    This Light & Motion Bluefin electronic underwater housing is for the Sony HDR-HC1 high definition camcorder. The housing is constructed from industrial grade aluminum, machined and anodized with a depth rating of 330'. All primary camera controls are accessed by infrared through the housing body. This prevents the need for mechanical controls to penetrate the housing, greatly decreasing the chance of a flood.
    The housing has an advanced feature set that is laid out in a compact, easy to use design. The housing features many important controls including power on/off, record start/stop, double tap variable zoom control, electronic manual focus and momentary auto focus on/off. The Housing also provides access to manual white balance, iris control and the tele macro function. The Smart Grip Handles provide access to VTR playback for instant footage review. Also included is a Flip Down Color Correction Filter that provides easy transitions between ambient and artificial light.
    The Bluefin HDR-HC1 housing comes standard with a zoom macro port. The port has a 65° viewing angle while still providing macro ability for close-up shots. Other ports are available.
    The kit includes the Light & Motion Sunray-S Pro lighting kit. The battery pods are a sleek low profile slim design that integrates neatly beneath the housing.
    The Sunray-S Pro light uses a 21w High Intensity Discharge (HID) lamp. The lamp is 2 to 3 times brighter then a halogen lamp. The color the light produces is a daylight like 5500° k
    Lights are extremely important for your underwater imaging system. The ocean is one big, blue filter. As you descend, the reds and oranges quickly become muted shades of blue and gray. Shining a color corrected light source on your subject will bring back your subjects natural color.
    Housing
    Rugged Construction Industrial grade aluminum, machined and anodized with stainless steel hardware with double o-ring seals that provides corrosion resistance and ideal protection in any environment Infrared Controls All primary camera controls are accessed by infrared through the housing body; This prevents the need for mechanical controls to penetrate the housing, greatly decreasing the chance of a flood Camera Controls Power on/off <li>Record start/stop <li>Double tap variable zoom control <li>Electronic manual focus <li>Momentary auto focus on/off <li>Iris control <li>Tele macro function <li>VTR playback <li>Flip filter Self Locking Rotary Latches Rotating latches are more secure and substantially easier to use than spring loaded clamps; Just rotate the latch and watch the rear plate glide smoothly into place; The latch is designed in such a way so as to draw the rear plate into the rear of the housing for a precise fit; Once engaged, the sliding lock snaps securely into place; Unlike a spring loaded mechanism, you won't accidentally bump the clamp open Included Lens System Zoom macro port, has a 65° viewing angle while still providing macro ability
    Sunray-S Pro Video Lights
    21w High Intensity Discharge (HID) produces 1302 Lumens Wide 80° beam angle 5500° K color temperature
